Plusnet fibre installation- cabling needed on fence?
Sam1dumplings
Hi
I'm thinking of moving from Plusnet Adsl to fibre - however, I believe the green cabinet in the road needs to connect to my master socket - is there a need to dig a trench to run the cabling to the property or tack the cable to a garden fence? Both of these are out of the question.
If fibre can be installed without the need for this, will proceed- any info on this welcomed many thanks
1 REPLY
Fixes: 58
Re: Plusnet fibre installation- cabling needed on fence?
It uses the existing wiring into your house so no new wiring
