Plusnet broadband unlimited keeps dropping out this afternoon
Legend
Fixes: 259
Re: Plusnet broadband unlimited keeps dropping out this afternoon
Thanks for that, Simon. Can you please run the BT Speedtest Additional Diagnostic again and post the result, along with your current Hub Helpdesk figures?
simonc2
I am trying to post a reply to this but whatever I post doesn't seem to be added to the thread. I'll keep trying.
Legend
Fixes: 259
What are you trying to post, and how?
simonc2
I had two screen shots of the speed tester plus a table of data from the Hub One helpdesk page. I'll try sending them one at a time.
simonc2
First go at speed test was not encouraging:
simonc2
2nd attempt a few seconds later was better:
Legend
Fixes: 259
That is terrible. Can you add the others, and we really need to see the Additional Diagnostic.
Legend
Fixes: 259
Still a poor result.
simonc2
I tried to add the output from the Hub One as a formatted table and that seems to be what was preventing it posting in the thread.
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ52928394
3. Firmware version: Software version 4.7.5.1.83.8.289.1.3 Last updated 16/11/21
4. Board version: Plusnet Hub One
5. DSL uptime: 1 days, 16:20:54
6. Data rate: 1013 / 14355
7. Maximum data rate: 1008 / 14368
8. Noise margin: 6.2 / 14.9
9. Line attenuation: 5.7 / 12.2
10. Signal attenuation: 5.7 / 10.7
11. Data sent/received: 186.5 MB / 6.0 GB
12. Broadband username: xxx@plusdsl.net
13. 2.4 GHz Wireless network/SSID: PLUSNET-68M7
14. 2.4 GHz Wireless connections: Disabled
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID: PLUSNET-68M7
18. 5 GHz Wireless connections: Disabled
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address: a0:1b:29:66:d8:fa
23. VPI/VCI: 0 / 38
24. Modulation: G.992.5 Annex A
25. Latency type: Interleaved
26. Software variant: AA
27. Boot loader: 1.0.0
Legend
Fixes: 259
Simon, I don't believe the issue is properly fixed - your D/S noise margin is still way too high, so there must still be an error somewhere, causing that - and your relatively poor download speed.
Aspiring Hero
Fixes: 80
Just a couple of thoughts @simonc2
Are you running the BTW Performance test from a wired connected directly to the router or wireless? Wireless testing can give spurious results.
Ping tests to plusnet DNS servers is not that reliable, I would suggest pinging
Address: 80.249.99.164
HTH
Legend
Fixes: 259
@Dan_the_Van Are ping tests really needed here? - I would be looking more at the actual speed test results and the other data provide.
Aspiring Hero
Fixes: 80
@jab1 Maybe you should look a bit better then.
If you check through the thread clearly you will see a ping capture in post #7 and two ping graphs post #8 and #15.
Personally I would have expected you have picked that up!
Legend
Fixes: 259
@Dan_the_Van I have seen them - I'm just wondering if they are really helpful.
Aspiring Hero
Fixes: 80
@jab1 I don't think they are, @simonc2 clearly thought they are useful. I wanted him to know he should use a more reliable target to ping.
Nothing else.
