Plusnet broadband unlimited keeps dropping out this afternoon
FIXED- Subscribe to RSS Feed
- Re: Plusnet broadband unlimited keeps dropping out...
Re: Plusnet broadband unlimited keeps dropping out this afternoon
10-10-2022 7:03 PM
Thanks for that, Simon. Can you please run the BT Speedtest Additional Diagnostic again and post the result, along with your current Hub Helpdesk figures?
10-10-2022 7:51 PM
I am trying to post a reply to this but whatever I post doesn't seem to be added to the thread. I'll keep trying.
10-10-2022 7:52 PM
What are you trying to post, and how?
10-10-2022 7:53 PM - edited 10-10-2022 7:54 PM
I had two screen shots of the speed tester plus a table of data from the Hub One helpdesk page. I'll try sending them one at a time.
10-10-2022 7:54 PM
First go at speed test was not encouraging:
10-10-2022 7:55 PM
2nd attempt a few seconds later was better:
10-10-2022 7:56 PM
That is terrible. Can you add the others, and we really need to see the Additional Diagnostic.
10-10-2022 7:57 PM
Still a poor result.
10-10-2022 7:58 PM - edited 10-10-2022 7:58 PM
I tried to add the output from the Hub One as a formatted table and that seems to be what was preventing it posting in the thread.
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ52928394
3. Firmware version: Software version 4.7.5.1.83.8.289.1.3 Last updated 16/11/21
4. Board version: Plusnet Hub One
5. DSL uptime: 1 days, 16:20:54
6. Data rate: 1013 / 14355
7. Maximum data rate: 1008 / 14368
8. Noise margin: 6.2 / 14.9
9. Line attenuation: 5.7 / 12.2
10. Signal attenuation: 5.7 / 10.7
11. Data sent/received: 186.5 MB / 6.0 GB
12. Broadband username: xxx@plusdsl.net
13. 2.4 GHz Wireless network/SSID: PLUSNET-68M7
14. 2.4 GHz Wireless connections: Disabled
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID: PLUSNET-68M7
18. 5 GHz Wireless connections: Disabled
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address: a0:1b:29:66:d8:fa
23. VPI/VCI: 0 / 38
24. Modulation: G.992.5 Annex A
25. Latency type: Interleaved
26. Software variant: AA
27. Boot loader: 1.0.0
10-10-2022 8:04 PM
Simon, I don't believe the issue is properly fixed - your D/S noise margin is still way too high, so there must still be an error somewhere, causing that - and your relatively poor download speed.
10-10-2022 8:18 PM - edited 10-10-2022 8:18 PM
Just a couple of thoughts @simonc2
Are you running the BTW Performance test from a wired connected directly to the router or wireless? Wireless testing can give spurious results.
Ping tests to plusnet DNS servers is not that reliable, I would suggest pinging
Address: 80.249.99.164
HTH
10-10-2022 8:27 PM
@Dan_the_Van Are ping tests really needed here? - I would be looking more at the actual speed test results and the other data provide.
10-10-2022 8:32 PM
@jab1 Maybe you should look a bit better then.
If you check through the thread clearly you will see a ping capture in post #7 and two ping graphs post #8 and #15.
Personally I would have expected you have picked that up!
10-10-2022 8:36 PM
@Dan_the_Van I have seen them - I'm just wondering if they are really helpful.
10-10-2022 8:43 PM
@jab1 I don't think they are, @simonc2 clearly thought they are useful. I wanted him to know he should use a more reliable target to ping.
Nothing else.
