Plusnet blocking udp to port 80
- Re: Plusnet blocking udp to port 80
09-09-2015 10:41 AM
I am having problems getting a list of computers to access remotely on a home based server. http ones are ok, but udp assigned ones do not show up unless they are also using plusnet as an isp.
Members area firewall has been turned off and router rebooted
This is not a PORT forwarding issue on my router or server.
Any suggestions ?
09-09-2015 12:13 PM
A warm welcome to the forums. Whilst I do not have an answer to your question, may I clarify your scenario?
At 'home' you have a server on which you are running a service on port 80 to which you want 'external' machines to connect to.
Either by port forwarding or putting that machine into the DMZ any machine can connect to the server on port 80 using http, regardless of the ISP
Any machine connected on / to the PlusNET network can also connect using udp
All machines outwith the PlusNET network cannot connect using udp with any non-PlusNET ISP.
Do you have a list of the other ISPs please? It would be interesting to see if there is a virtual ISP involved for which PlusNET is the privider, for example John Lewis.
09-09-2015 12:29 PM
One that can connect and I know uses plusnets network is One2Call
Ones that cannot include BT both Home and Business Broadband, TalkTalk and Virgin Media. They can connect on these networks if they are configured to use UDP port 8008
Si
dick:quote
09-09-2015 1:49 PM
Doing traceroutes from external hosts, to UDP port 80 on Plusnet hosts, might show where they're being blocked.
11-09-2015 11:39 AM
Quote from: ejs Doing traceroutes from external hosts, to UDP port 80 on Plusnet hosts, might show where they're being blocked.
This would certainly help.
I don't have access to an off-network Linux device at the moment, but if anybody does then I'd be interested to see the output from:
$ traceroute -U -p 80 <plusnet customer's IP address>
Edit: edited to include -U switch.
11-09-2015 11:51 AM
adw@avatastic:~$ traceroute -U -p 80 84.92.xx.xx
traceroute to 84.92.xx.xx (84.92.xx.xx), 30 hops max, 60 byte packets
1 213-138-103-3.no-reverse-dns-set.uk0.bigv.io (213.138.103.3) 3.175 ms 3.133 ms 3.061 ms
2 te3-4.cr2.man.bytemark.co.uk (91.223.58.64) 0.573 ms 0.736 ms 0.815 ms
3 te0-0-2-0.cr1.lon.bytemark.co.uk (91.223.58.34) 7.288 ms 7.485 ms 7.507 ms
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
edited
11-09-2015 11:59 AM
11-09-2015 12:04 PM
11-09-2015 12:18 PM
andy@mc:~$ traceroute -U -p 80 84.92.x.x
traceroute to 84.92.x.x (84.92.x.x), 30 hops max, 60 byte packets
1 10.0.0.1 (10.0.0.1) 0.385 ms 0.364 ms 0.357 ms
2 * * *
3 * * *
4 stn3-edge-02.inet.qwest.net (65.122.30.1) 1.530 ms 8-1-21.ear3.Washington1.Level3.net (4.79.22.93) 1.276 ms 1.505 ms
5 dcp-brdr-03.inet.qwest.net (205.171.251.106) 2.439 ms * *
6 * 166-49-169-109.eu.bt.net (166.49.169.109) 2.538 ms 2.536 ms
7 ae-44-44.ebr2.London1.Level3.net (4.69.137.77) 74.223 ms 74.212 ms t2c3-xe-11-0-0-0.uk-lof.eu.bt.net (166.49.208.52) 82.913 ms
8 213.137.183.39 (213.137.183.39) 87.361 ms ae-56-221.csw2.London1.Level3.net (4.69.153.130) 74.186 ms 213.137.183.33 (213.137.183.33) 81.662 ms
9 ae-227-3603.edge3.London1.Level3.net (4.69.166.154) 74.445 ms core3-te0-17-0-0.faraday.ukcore.bt.net (62.6.201.166) 82.200 ms ae-227-3603.edge3.London1.Level3.net (4.69.166.154) 74.182 ms
10 acc2-10GigE-0-4-0-10.l-far.21cn-ipp.bt.net (109.159.249.134) 82.482 ms BT-NET.edge3.London1.Level3.net (195.50.124.70) 74.479 ms acc2-10GigE-0-3-0-2.l-far.21cn-ipp.bt.net (109.159.249.172) 87.378 ms
11 166-49-168-114.eu.bt.net (166.49.168.114) 88.057 ms 88.012 ms *
12 core1-te0-5-0-4.ilford.ukcore.bt.net (194.74.77.173) 91.078 ms 89.777 ms www.londonlink.com (194.72.7.41) 77.972 ms
13 core4-te-0-0-0-2.faraday.ukcore.bt.net (213.121.193.57) 81.687 ms * *
14 acc2-10GigE-0-3-0-0.l-far.21cn-ipp.bt.net (109.159.249.168) 81.660 ms * acc2-te0-0-0-1.l-far.21cn-ipp.bt.net (109.159.249.190) 77.069 ms
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
edited
11-09-2015 12:27 PM
traceroute -U -p 80
Otherwise traceroute is incrementing the port number with each probe it makes.
11-09-2015 12:29 PM
11-09-2015 12:51 PM
It shows port 80 tcp to be open -- confirms my port forward rule is working.
It shows my port 80 UDP to be "Not Open" -- suggests it's being blocked externally.
11-09-2015 12:59 PM
Quote from: ejs We need to fix the traceroute invocation. It should be: traceroute -U -p 80
Good point.
Quote from: avatastic Traces edited. That looks conclusive to me...
It does, I'll see if I can get somebody to take a look...
Edit: ref 87983
