Plusnet assist update not working
grahamjohn
I had a Plusnet Assist pop up stating that XP, Vista and Windows 7 users have an important up date which I clicked. This opened Explorer with the message: This update requires elevation..and so on ..click Next. When I click next on my laptop (Vista) and my PC (7) nothing happens!
Please advise.  Undecided
Graham
Fixes: 21
Re: Plusnet assist update not working
Was the message referring to a Windows Update or a Plusnet Assist update?
Just manually run Windows Update?
Then uninstall Plusnet Asist??  Wink
Call me 'w23'
grahamjohn
This is a Plusnet Assist update.
If it's failing to update itsself then uninstall.
Re-install after if you find it useful (hopefully the reinstall will be the updated version).
Call me 'w23'
grahamjohn
Many thanks for the advice, I can re-install ok but as there is a problem with Plusnet Assist I will see if plusnet resolve it first. I have used Assist a few times and have found it to be very useful.
Plusnet Staff
Plusnet Staff
Fixes: 5
Did uninstalling and reinstalling Plusnet Assist resolve the issue for you?
The more information we can collate, we can then look into any issues that arise Smiley
Chris Pettitt
Cloud Environments Engineer
Quote from: grahamjohn
...there is a problem with Plusnet Assist...
Was there any problem other than failing to update?
Call me 'w23'
You need to run the update as administrator.
Dan.
@Dan, your eyes (or brain?) are better than mine!
Well spotted, especially if it turns out to be the solution!
Call me 'w23'
@walker23
Hopefully it will, I've come across this problem a few times.
Dan.
grahamjohn
Thanks for all the advice so far. I know how to run Plusnet assist as and Adminstrator but I do not see how to run the update as one. A pop up appears which when clicked on opens IE with the option only to click next.
How will I know if I uninstall and re-install Plusnet Assist I have the new version or my original version?
Fixes: 62
I suggest opening IE as Administrator - right click on shortcut and select Run as administrator - then try the update.
It should use the existing open application rather than starting a second one
Fixes: 162
I've asked our Plusnet Assist guru for any advice they might have on this too.
 Chris Parr
 Plusnet Staff
grahamjohn
Hi, I have uninstalled and reinstalled Plusnet Assist on my laptop. I am unable to tell if the version is the new one except for the date created is now today's date.
If I run IE as an administrator and open Plusnet Assist it gives me the Plusnet Assist home page online and there is no way to force the update that I can see.
Am I missing something here?
Thanks everyone.
