Plusnet assist update not working
- Re: Plusnet assist update not working
27-06-2012 5:53 PM
Please advise.
Graham
27-06-2012 6:52 PM
27-06-2012 8:00 PM
Then uninstall Plusnet Asist??
27-06-2012 8:02 PM
27-06-2012 8:07 PM
Re-install after if you find it useful (hopefully the reinstall will be the updated version).
27-06-2012 10:32 PM
28-06-2012 10:29 AM
The more information we can collate, we can then look into any issues that arise
28-06-2012 11:26 AM
Quote from: grahamjohn ...there is a problem with Plusnet Assist...
Was there any problem other than failing to update?
28-06-2012 11:35 AM
Quote This update requires elevation..and so on ..click Next. When I click next on my laptop (Vista) and my PC (7) nothing happens!
You need to run the update as administrator.
Dan.
28-06-2012 11:39 AM
Well spotted, especially if it turns out to be the solution!
28-06-2012 11:45 AM
Hopefully it will, I've come across this problem a few times.
Dan.
28-06-2012 3:57 PM
How will I know if I uninstall and re-install Plusnet Assist I have the new version or my original version?
28-06-2012 4:00 PM
It should use the existing open application rather than starting a second one
28-06-2012 4:02 PM
28-06-2012 4:25 PM
If I run IE as an administrator and open Plusnet Assist it gives me the Plusnet Assist home page online and there is no way to force the update that I can see.
Am I missing something here?
Thanks everyone.
