Plusnet are routing our traffic through a transparent proxy!
SamCulley
I noticed a squid error page which you can see above and I have also attached.
Cry
Fixes: 20
Re: Plusnet are routing our traffic through a transparent proxy!
Fixes: 260
I believe all UK ISP's do.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
SamCulley
Quote from: ejs
It's just the IWF proxy: http://www.plus.net/support/security/abuse/iwffaq.shtml
Makes total sense then actually.
Fixes: 163
imgur.com is working from my home connection again this morning, anyone still having problems?
 Chris Parr
 Plusnet Staff
Fixes: 96
Caused by this by the looks of things.
Quote from: dvorak
Not all of them
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
