Plusnet and Mobile devices
- Plusnet and Mobile devices
24-10-2007 3:11 PM
Do plusnet offer a dialup service for use with movbile devices i.e pdas
i might be getting a pda from work with satnav but i would like to find out if plusnet offer a dialup service for mobile devices and wetehr it could be tied into part of my account?
Message 1 of 4
(1,191 Views)
3 REPLIES 3
Re: Plusnet and Mobile devices
24-10-2007 4:22 PM
PDAs don't tend to have modems any more. If they have WiFi then you can upgrade your account to allow roaming, or if its a SmartPhone use the telephony provider to connect to the Internet (GPRS, 3G etc) then you can access your PlusNet account as normal...
Message 2 of 4
(352 Views)
24-10-2007 4:27 PM
Hi there
Does this link help at all:
http://www.plus.net/support/email/setup/mobile_phone_email.shtml
We were talking about this yesterday evening interestingly enough.
HTH
Emma
HTH
Emma
Message 3 of 4
(352 Views)
24-10-2007 10:24 PM
Well its a Pin570 so its quite old but that helps loads thanks
Message 4 of 4
(352 Views)
