Plusnet Unlimited very slow!
- Plusnet Unlimited very slow!
01-08-2012 9:18 PM
Are there any other Fiber customers been moved back to ASDL? My speed is:-
Download speed is now 3.88 Mbps
Upload Speed is now 0.09 Mbps
Ping is 72.13ms
Is this normal?
Ping is 72.13ms
Is this normal?
Message 1 of 9
(1,786 Views)
8 REPLIES 8
Re: Plusnet Unlimited very slow!
01-08-2012 10:10 PM
Join the club mate! snail slow isnt it
Message 2 of 9
(699 Views)
01-08-2012 10:20 PM
The high ping and low upload speed could both be due to some P2P program running and uploading, in the background or on another computer.
But your download speed of 3.88 Mbps is still faster than mine, considering I'm connected at 3712 kbps with a line attenuation of 58 db.
Message 3 of 9
(699 Views)
01-08-2012 11:37 PM
My router sats are:-
ADSL Link Downstream Upstream
Connection Speed 19864 kbps 443 kbps
Line Attenuation 10.1 db 5.5 db
Noise Margin 6.0 db 32.5 db
Not sure why the line is so slow as only a PC running with no background tasks.
Just hope Plusnet can sort it?
Message 4 of 9
(699 Views)
02-08-2012 9:20 AM
Can you post the results of a BT speed test and what your current line speed is here https://portal.plus.net/my.html?action=stable_rate please.
Message 5 of 9
(699 Views)
02-08-2012 10:01 AM
Hi BigNez,
Your IP profile is set up correctly, so you shouldn't be seeing those results. Are you connected with an ethernet cable or wireless?
If you are using wireless, try an ethernet cable, if your still getting slow speeds I'd suggest <a href="http://faults.plus.net">raising a fault</a> to resolve this.
As Jelv mentioned in the previous post, you will need to complete 3 BT speed tests, prior to running them it will give you a set of instructions to ensure your set-up is correct.
Chris
Chris
Message 6 of 9
(699 Views)
02-08-2012 8:52 PM
I have raised a ticket (58306279) and sent in 3 BT speed tests.
High-speed Broadband
Estimated line speed:
7Mb (Accurate to within +/- 1Mbit) - Checked on 2012-07-18 14:15:11
Current line speed:
17.5 Mb
BT Speed test Data tonight
Download Speed 3.73 Mbps
Upload Speed 0.05 Mbps
Ping 43.75 Mbps
I am using Cat 5e cables to my router
Current line speed:
17.5 Mb
Ping 43.75 Mbps
Message 7 of 9
(699 Views)
02-08-2012 9:16 PM
Quote Your IP profile is set up correctly, so you shouldn't be seeing those results. Are you connected with an ethernet cable or wireless?
If you are using wireless, try an ethernet cable, if your still getting slow speeds I'd suggest raising a fault to resolve this.
I wish I could my connection is slow the portal just Hangs on fault reporting!
Message 8 of 9
(699 Views)
02-08-2012 9:19 PM
Try telephoning Residential Support 0800 432 0200 or 0345 140 0200
Message 9 of 9
(699 Views)
