Plusnet - Talk Talk Speed difference
dmitrijs1
Same house diferent socket makes so much diference
Will your test show where is the problem?
Fixes: 62
Re: Plusnet - Talk Talk Speed difference
Post split off to it's own thread and title changed
You appear to have a second line from Plusnet - is this correct
glloyd
Avast anti virus did not like those images says they are infected with a virus.
Fixes: 62
Kaspersky is very happy with them - get a decent anti virus  Shocked
newagetraveller
Or, Avast is indicating a genuine threat and Kaspersky isn't. So get a decent antivirus. Roll eyes
Three mobile, 1,2,3, PAYG. https://www.three.co.uk/Store/SIM/Pay_As_You_Go
dmitrijs1
Yes second line was Plusnet
Line was OK
It was getting to many erors so Bt capped me at 0.35 mb/s
Today BT enginier ran tests
Remove cap
ran test get alot of crn or icr errors on download so he changed connection from fast to interlink or somthing and he said its was becouse i am to far awai now getting better staible connection
Than ring plusnet support remove cap
and getting 4 megs when before was 2000 - 3500
So its settings at bt that matter
Happy TY for all
Same wire but diferent settings
NorthEasterner
Do a speedtest for both providers
and post them on here for us to see?
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
dmitrijs1
And TALK TALK slower even it show not that much diference in test diference is huge
And some games and web pages don show videos and games say that on Talk talk i am bihind firewall lol
After line on plusnet reseted never had any problem always good ping in game and youtube works well
Same for upload speeds
dmitrijs1
Had some problems on the line so was doing this and that changing adls2 modes
start to get best speed and when you watch youtube line dont drop in middle of hd1080 video so you can watch having no buffering in middle of movie
Also improved download speed even actual speed on speed test lower, internet download manager 6.14 makes some difference
So try MTU lowering in router it my help allot
i was doing this in cmd
ping www.google.com -l 1300 -n 10 -f
where 1300 is mtu that i put in router after testing becouse 1350 and higher keept loosing pacets or didn't work lowering this to 1300 i had stable packets in out no more los at all
and then you need to change mtu in windows what i did but i thing router is that moust you need changing so i did it only becouse found how to but was working fine whet 1500 mtu default in windows thats what you do in cmd
netsh>                                     interface
netsh interface>                    ipv4
netsh interface ipv4>            show subinterface
      show subinterface
  MTU  Состояние определения носителя   Вх. байт  Исх. байт  Интерфейс
 1260                1          0     265835  Loopback Pseudo-Interface 1
 1260                1  1061249323   40768640  Подключение по локальной сети
 1500                5          0          0  Подключение по локальной сети 2
 1500                5          0          0  Сетевое подключение Bluetooth 2
     set subinterface "1" mtu=1260
then type again to check if it changed
     show subinterface
Even under high download load i still can use brodband and surf net easy and no peak times  Cheesy as normali in 6-8 18-22    was the worst broadband but not enymore now i can even play games so almoust forgot about peak times ty plusnet for all that time spend on me trying to solve problem on line
Plusnet Staff
Plusnet Staff
Fixes: 5
It's amazing how much of a difference it makes, you can forget what you can use the internet for when you start to get improved speeds.
Glad everything has been sorted out for you Smiley
Chris Pettitt
Cloud Environments Engineer
dmitrijs1
Cheesy Yeap speed is very staible even at peak times and goes from 480 to 700
