Plusnet Speed Tester
- Plusnet Speed Tester
05-10-2011 1:50 PM
Is anyone else having a problem with the speed tester today? When I click the 'begin' button nothing happens.
adie:green all caps title removed as per link:rules]
Message 1 of 6
(1,043 Views)
5 REPLIES 5
Re: PLUSNET SPEED TESTER
05-10-2011 1:56 PM
working fine here.
Message 2 of 6
(450 Views)
Re: Plusnet Speed Tester
05-10-2011 1:58 PM
OK here also.
Message 3 of 6
(450 Views)
05-10-2011 2:51 PM
OK thanks. It seems to be a problem with my system then. Possibly the fact that I am not running the latest Flash Player version?
Message 4 of 6
(450 Views)
05-10-2011 3:03 PM
Yes, that was the problem! Interesting as I had not been offered an update and the speed tester did not report a problem but just sat there.
adie:quote
adie:quote
Message 5 of 6
(450 Views)
06-10-2011 7:31 PM
My speedtester will not work using 64 bit (Windows 7, IE 9), apparently because Flash Player is not yet compatible, but works fine on 32 bit.
Message 6 of 6
(450 Views)
