Plusnet Sagemcom 2704N Router advise?
- Re: Plusnet Sagemcom 2704N Router advise?
14-02-2015 9:30 PM
I believe this is a new router recently released so obviously there has to be software bugs in it until new firmware iron these bugs out so what are the common issues with this router so I know what to look out for?
Also Ethernet 4 port at the back is specially highlighted pink compered to the other three Ethernet ports. Why is that?
14-02-2015 9:46 PM
There are no reported bugs or problems as yet.except if you want to do something which isn't supported
It might be worth reading this http://community.plus.net/forum/index.php/topic,135846.0.html
Normally firmware upgrades (this is for the previous routers) are carried out by the user but can be done remotely if requested
14-02-2015 11:07 PM
This router cannot be updated by the user such as me?
adie:quote
14-02-2015 11:31 PM
The router software is specially configured by Plusnet. If new software is made available I expect Plusnet will announce how it can be updated.
15-02-2015 11:05 AM
jim:quote
15-02-2015 12:19 PM
You use the ADSL port which has the modem built in to plug into your phone line.
15-02-2015 1:37 PM
In ADSL mode the pink port behaves just like the other three Ethernet ports, so you can connect a power line adapter to it if desired.
15-02-2015 6:24 PM
Does the same apply to PlusNet?
16-02-2015 10:19 AM
Quote from: spraxyt In ADSL mode the pink port behaves just like the other three Ethernet ports..
Does that mean you don't need one of these? http://www.network-cabling.co.uk/store/product_info.php/cat5e-moulded-patch-lead-025m-pink-p-2754?gc...;
16-02-2015 5:24 PM
17-02-2015 2:04 PM
17-02-2015 2:24 PM
If you mean about xbox settings, see http://www.plus.net/support/broadband/hardware/plusnet-2704n-faqs.shtml#advanced may be helpful, there is also some useful comment here.
If it's something else or you have difficulty with that, you may be better posting about it in the thread mentioned in reply #1 which will help keep info together.
18-02-2015 7:12 PM
Also cant see a option to change the router password
18-02-2015 8:08 PM
I don't think you've said if you're on ADSL or FTTC yet ?
18-02-2015 9:13 PM
