Plusnet SafeGuard - Gaming - Ping
- Plusnet SafeGuard - Gaming - Ping
01-06-2018 4:36 PM
Hi all,
We do a lot of online gaming Ps3/Ps4 in our household.
I'm a new customer - 'Copper BB'.
With Plusnet SafeGuard - is it likely that it affects pings in some way - putting us at a competitive disadvantage?
Q1: What affect does 'SafeGuard' have on download speed, upload speed - latency & ping?
Q2: Will turning it off make a difference?
Re: Plusnet SafeGuard - Gaming - Ping
01-06-2018 4:46 PM
01-06-2018 5:47 PM
Fibre would improve all of your desired features.
You could always turn Safeguard off for a while to see if it makes a noticeable difference.
06-06-2018 3:35 PM
Appreciate the advice on this.
It seems quite clear the only way to be sure is to try and see. I'll be waiting till our initial DLM run has finished - then will try with it off and on at different times - then report back.
06-06-2018 3:45 PM
