Plusnet Profile stuck... again
docrobster
Test1 comprises of Best Effort Test:  -provides background information.
Download  Speed
426 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 426 Kbps
Additional Information:
Your DSL Connection Rate :3712 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 3000 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
this has been the situation at least overnight. I am led to believe the PN profile should catch up "within 12 hours" but:
Phone exchange:
RANMOOR
Estimated line speed:
0.5 - Checked on 2010-04-17 23:34:09
Current line speed:
500
Last time this happened a helpful soul on here sorted it out.
Any chance of the same thing happening again/
Thanks in advance
Rob
ChrisL
Re: Plusnet Profile stuck... again
This is unlikely to be picked up at the weekend...  You could probably acheive the same thing today by phoning support?
Best wishes
Chris
docrobster
Hmmm, just spent 7 minutes on the phone to a call centre in ?South Africa to be told it can't be changed manually, but will happen automatically and I will just have to wait it out.
Hence my asking here- seems more effective usually Wink
HaydnExport
It can be changed manually as i have rang them a couple of times.
docrobster
Another 24hours has passed and still stuck. This is getting rather annoying.
Hi docrobster,
Upped to 3000 to match for you, sorry for the delay.
docrobster
Thanks.
