Plusnet Pro and webserver/own website
- Re: Plusnet Pro and webserver/own website
02-08-2013 11:13 PM
If i add "plusnet pro" to my fibre broadband , is running your own web server/website allowed? I thought it was a given but ive heard some isp's frown upon it?
Matt
Matt
Message 1 of 3
(1,379 Views)
2 REPLIES 2
02-08-2013 11:36 PM
Why would you add Pro - I assume that you are on the Unlimited product
Plusnet don't give a hoot about you running your own server/website as long as it isn't a commercial operation then you should move to a business product
Message 2 of 3
(306 Views)
03-08-2013 1:03 AM
The only thing you may want to buy is a static IP, but it should work fine without (can use a dynamic DNS provider to access remotely)
Message 3 of 3
(306 Views)
