Plusnet Pro Addon - 25/03/2013
Necrotix
Hey there guys,
Just a quick post to ask if the Plusnet Pro addon is still viable?
I understand you had a massive shake-up of all your packages, so I was just wondering if the Pro addon still makes a difference for gaming?
Also, aside from traffic management, does the Pro addon do anything other than that?
Cheers.
Fixes: 10
Re: Plusnet Pro Addon - 25/03/2013
It's still available.
If you are on unlimited it's a waste of money!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
bomster
I'm purely paying for this service with the intention of my ping being lower, and getting no (or less) throttling on P2P and other servies.
Am I wasting my money?
Fixes: 62
What product do your questions relate to? Most of the legacy products had speed caps in the busy evening period and the Pro Add-on removed those. The new Unlimited product does not have any speed caps so nothing for the Pro Add-on to remove.
The Pro Add-on does prioritise more protocols but this would become important only if Plusnet were short of bandwidth.
The Pro Add-on does not directly affect ping but might have a secondary effect through removing speed caps.
David
Necrotix
Hey guys.
Thanks for the replies. Really helpful.
Well I was referring to the current products. I'm a fairly new Plusnet customer and moved to Plusnet after the product changes happened, so I was just making sure that I wasn't missing anything by NOT having the pro addon. I play a lot of games, you see.
It's a bit confusing because it's still possible to purchase the Pro addon.
