Plusnet Portal - High Speed Broadband - Current Line Speed
- Plusnet Portal - High Speed Broadband - Current Li...
23-09-2013 7:48 AM
A while ago I had an ADSL faceplate fitted and noticed the router sync speed increased to 11649. But speedtest results seem to be stuck at around 9.7M, I have checked on the BT speedtest and it says
Download speed achieved during the test was - 9.32 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 10.28 Mbps
And on the plusnet portal under High Speed Broadband it says
Estimated line speed:
Current line speed:
9.8 Mb
What is this 'current line speed'?
Current line speed:
9.8 Mb
Message 1 of 3
(709 Views)
2 REPLIES 2
Re: Plusnet Portal - High Speed Broadband - Current Line Speed
23-09-2013 8:15 AM
current line speed is the profile set on PN -Should be the same as BT profile -with a synch of 11649 your BT/PN profiles SHOULD be 88.2% of synch speed ie 10274,so BT is right -PN have just not caught up yet.
Message 2 of 3
(330 Views)
23-09-2013 4:20 PM
Hi cjags, just updated your profile to 10200 to match the BT side of things, hope that helps.
Message 3 of 3
(330 Views)
