Plusnet POP3 email while at university
- Plusnet POP3 email while at university
22-09-2008 12:26 PM
Re: Plusnet POP3 email while at university
22-09-2008 12:36 PM
22-09-2008 3:27 PM
As madjbright has said, your daughter will need to set up authenticated SMTP in Thunderbird (so she can log on to PN's SMTP server) which will allow use of the SMTP server "off net".
To do this, she'll need to open Thunderbird and go to Tools>Account Settings then select "Outgoing SMTP Server" from the list.
In the box she should select relay.plus.net and enter your PN username (also make sure encryption is set to none). TB will promt her for your PN password when she tries to send a mail. She should tick the "remember password" box.
It's important that she uses your account username and password as it won't work otherwise. These are the same as you use to login to the portal (i.e. without the @plusdsl.net).
Edit: typo
22-09-2008 3:28 PM
The outgoing server name would need to be relay.plus.net
22-09-2008 3:30 PM
22-09-2008 4:02 PM
Quote from: Paul03 you can usually only send mail using the SMTP server of the ISP you're currently connected to.
This is commonly referred to as "blocking port 25", though the means and level of implementation vary a lot.
The simplest thing to do is to get her to ask the University IT/Internet services what facilities they provide for sending SMTP email for accounts held elsewhere. The answer may actually be "none at all" but that would be relatively rare.
If it is "none" then she'll only be able to send via a genuine uni account or webmail.
22-09-2008 5:32 PM
22-09-2008 7:10 PM
Quote from: Jameseh Sorry Paul, not meaning to be pedantic at all.
thats assuming you are not a F9 or free-online member
22-09-2008 9:11 PM
22-09-2008 9:27 PM
23-09-2008 12:52 PM
I move my mail away from PN when they famously removed it from me 🙂 Glad those days are over. That beside surely smtp authentication just needs the specific email addreses passowrd insterted for authentication i.e your daughters email password and NOT the main account password. That's how my host works but I guess each company set things up differently.
do you not trust your daughter with the password ? If she's feeling rich she could log on and pay your account 🙂
Podman
23-09-2008 1:18 PM
With PN's implementation you need the main account username and password and not those associated with a particular mailbox.
23-09-2008 1:56 PM
Podman
06-10-2008 2:51 PM
