Plusnet, Mozilla Thunderbird and SMTP relay.plus.net
- Plusnet, Mozilla Thunderbird and SMTP relay.plus.n...
25-08-2009 11:00 AM
I have more than one mail box with Plusnet that are set up with separate in boxes in Thunderbird. Thunderbird gives its instructions how to set up separate SMTP servers for each account, so that reply emails posted by me will be sent from the one the original message was received by, and not the principal account, unless I alter the sender details.
However, is it possible to have anything other than relay.plus.net, similar to the pop settings x+y mail plus net?
Message 1 of 5
(1,260 Views)
4 REPLIES 4
Re: Plusnet, Mozilla Thunderbird and SMTP relay.plus.net
25-08-2009 11:40 AM
You will only be able to send email via us through relay.plus.net
I think what you actually mean is that you want to change the reply-to address?
You should be able to change this in the account settings: tools/account settings/account name/reply to address
Message 2 of 5
(479 Views)
25-08-2009 1:09 PM
Thanks Janeseh for your mind reading skills As it doesn't produce anything my end no worries, but I an curious why a Rely to line appears in "To, CC, BCC" panel as well as the address of the intended recipient.
My knowledge is minute but I'm a nosey old git.
Message 3 of 5
(479 Views)
25-08-2009 1:56 PM
Don't worry too much about that bit.
The top line should always be the "reply-to" which you can manually change should you want to.
In the subsequent lines, you can then elect to direct reply or CC/BBC other email addresses.
Message 4 of 5
(479 Views)
25-08-2009 2:10 PM
Once again thanks.
Message 5 of 5
(479 Views)
