Plusnet Hub One & ADSL
trymyluck
I have recently received a Plusnet Hub 2 making my Hub 1 redundant.  My daughter has Plusnet ADSL internet with supplied router.  Would my redundant Hub 1 router work on my daughter's Plusnet ADSL broadband and, if it would, is it likely to provide any better service to her than her present ADSL router?
3 REPLIES 3
Mustrum
Fixes: 81
Re: Plusnet Hub One & ADSL
Yes and proably - you will need to adjust the username and passworf.
trymyluck
Thanks Mustrum.  That's helpful.
bobpullen
Fixes: 330
@trymyluck - if you are planning on giving your Hub One to your daughter then I would recommend we correctly associate the hub with her account to avoid any issues with the automatic configuration. Feel free to drop me a private message containing your hub serial number and her account username and I'll do the honours.
