Plusnet Hub 2 constantly cycling lights and losing connection
SeraRose
Hi
Finally got my new home connected to plusnet. We got a new Hub 2 and for a few days everything has been fine. We have noticed that intermittently, the hub starts flashing orange lights, then goes static orange and the blue. This has only been once in a while - annoying but can live with it. But today, the hub has been cycling through this every ten minutes or so.
We had to have a new line put in, used a new filter on the line etc.
3 REPLIES 3
Fixes: 306
Re: Plusnet Hub 2 constantly cycling lights and losing connection
@SeraRose sounds like you have an error on either the phone or broadband side of your connection.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
SeraRose
Hi. I don’t have a landline phone. Do I just jump straight to reporting a broadband fault?
Fixes: 306
You could, but a cheap wired handset is an essential aid for solving problems on an ADSL/FTTC connection.
