Plusnet HELP bot does not recognize my number?
- Re: Plusnet HELP bot does not recognize my number?
4 weeks ago
I was debugging some latency splikes and I texted 07400 008121 with HELP and it replied and I did the next step with my phone number but it is not recognized.
I have done this many times before and it used to work and often resolved my issues.
The only thing I can think of that changed is that I was "upgraded" recently and got a new plusnet router, and possibly moved over to some new subscription model or something. I still see my usual number on my account when I log in.
4 weeks ago
@dcdc If you are now on SoGEA, without a phone, the system can't cope. You will need to call in.
4 weeks ago
Strange. This is a new thing right? I used to be able to simply chat in and the bot did some checks.
4 weeks ago
@dcdc If, as I suggested above, you no longer have a phone service, then your 'phone number' is meaningless and as I also said, PN appear to have forgotten to put in place a replacement identifier for your connection.
3 weeks ago - last edited 3 weeks ago
AFAIK The Bot is supposed to attempt to match the mobile number from which the text is sent, to a mobile registered on an account. If it can find a match it should automatically identify the account without requesting a landline number.
3 weeks ago
@MisterW It is obviously not doing that though - ISTR at least one other user having this problem.
3 weeks ago
Yup!. Its been brought up and I'm not sure the reasons for its failure sometimes, have been established
3 weeks ago
I *never* had a phone service. NEVER EVER.
Yet it used to work.
3 weeks ago
You must have had a phone connection, though - ADSL and FTTC both run over the copper which provided the phone service.
As stated your ADSL / FTTC connection was controlled by a phone line with a number - even if you didn't use it.
You could try logging into your PN Members portal and under Account Details change your phone line number to your mobile number.
Edit Only do this if the upgrade was to FTTP. IF you went to a SOGEA account I'm not certain what would happen.
3 weeks ago
Yes, but I would *still* have that if that is the case and am not even aware of any phone number for whatever that is.
3 weeks ago
My phone number in my account is my cell phone number. I don't think I've ever known my "line" phone number.
3 weeks ago
If you log into your account and click the 'Manage Account' tab, the resulting page will detail the 'phone number' your service is/was provided over, although if you are on a SoGEA connection, as it appears you are, it is irrelevant.
3 weeks ago
There's also a 'mobile number' field there.which is used for things like text message notifications for order status etc
That's probably the number the bot is trying to match
3 weeks ago
Is that field filled in correctly, though?
