Plusnet Gateway PTN-AG04 Querry
- Re: Plusnet Gateway PTN-AG04 Querry
19-07-2013 2:50 PM
I had been connected to the above ptn-ag04 GW for over 1 week, until early this morning @ around 5am, My PPP session got dropped for no apparent reason as far as i can tell, I noticed because i was using the connection at that time, and it for some reason wouldn't re connect, any reasons as to Why this happens ?
my router tried for around 20 mins to re establish a session, i had to manually stop it from trying to connect and initiate the connect sequence, It then connected again, Did anyone else who was on the above gateway get kicked too ,or was it just me ?
Message 1 of 4
(1,003 Views)
3 REPLIES 3
23-07-2013 1:01 PM
If it was just a PPP disconnect and you remained in synch then it's likely to have been the result of localised outage/maintenance affecting BT Wholesale's network or the result of us manually disconnecting customers to bring the network back into balance following this work.
Message 2 of 4
(371 Views)
23-07-2013 4:02 PM
Ok, so that could /would be the cause of the loss of PPP ,but why couldn't the router establish a new PPP session by it's self, it normally does this without problems, But in any case I'm reasonably happy with the GW i'm currently on
Message 3 of 4
(371 Views)
24-07-2013 9:35 AM
Does seem odd, unless for some reason the connection kept routing to the gateway that was under maintenance - if so that will have cleared itself out as soon as you connected manually. Sorry about that, but glad to hear things are all working.
Message 4 of 4
(371 Views)
