Plusnet Fibre (SOLVED so it seems)
Timalay
I've just had Plusnet Fibre installed, now the speeds I should be getting (according to the openreach chap) are about 60mbps up and about 17mpbs down.
I've just done a speed test and I'm getting this.  Now he reckons it might be the cable conecting the router and the pc needs replacing.  Does this sound right?
Fixes: 162
Re: Plusnet Fibre
Log in to the router. disconnect/reconnect and try again Wink
 Chris Parr
 Plusnet Staff
Timalay
Re: Plusnet Fibre
Not to worry, after going upstairs and setting up my xbox 360 and my laptop.  It has now gone up - http://speedtest.net/result/2405339873.png.
