Plusnet Extra Fibre question
- Plusnet Extra Fibre question
15-09-2012 9:40 PM
Re: Plusnet Extra Fibre question
15-09-2012 10:23 PM
15-09-2012 10:50 PM
1. Best Effort Test: -provides background information.
Download Speed
61.64 Mbps
0 Mbps 77.43 Mbps
Max Achievable Speed
Download speedachieved during the test was - 61.64 Mbps
For your connection, the acceptable range of speedsis 12 Mbps-77.43 Mbps .
Additional Information:
IP Profile for your line is - 77.43 Mbps
Upload Speed
15.54 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 15.54Mbps
16-09-2012 9:29 AM
16-09-2012 10:30 AM
16-09-2012 11:12 AM
16-09-2012 2:49 PM
60Mb (Accurate to within +/- 1Mbit) - Checked on 2012-08-21 19:43:05
Current line speed:
78 Mb
bit confusing.
16-09-2012 2:59 PM
How do you connect to the router, wired or wireless?
16-09-2012 4:46 PM
17-09-2012 12:28 PM
As you have only just gone over to our 80/20 product, we have set your profile to 78MB/s to allow the maximum speed that your line can support, this will alter once we establish what your line speed will run at.
Your estimated line speed is 60.7MB/s so your speed result at the time you ran it appear to be OK.
Are your speeds fluctuating? If so by how much?
Chris
17-09-2012 4:25 PM
When synchronised at these levels, then the highest speeds I usually see (at speedtest.net) are between 73 and 75Mbps downstream and 16Mbps upstream.
The BT Speedtester just doesn't ever seem to give high results consistently, especially on downstream.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
17-09-2012 7:41 PM
Quote from: chrispurvey Hi tonka,
Chris
they are fluctuating but not too bad only 5 to 10 or so
18-09-2012 12:44 PM
18-09-2012 6:50 PM
19-09-2012 11:00 AM
I would suggest to monitor your connection and if it was to drop lower or you notice any pattern to the times them to make a note of these.
