Plusnet DNS Issues
Fixes: 585
Re: Plusnet DNS Issues
or maybe Sky DNS is only reachable within the Sky network
That's likely. Certainly PNs DNS are only accessible from a PN connection.
Starlink666
Well the BT / Plusnet DNS Servers are still not resolving my domain unfortunately. This morning I switched the nameservers over to Cloudflare but so far this has not helped. I'll give it a couple more days before deciding on the next steps. Is there anyone else that I can escalate this to? I'm not really getting anywhere with Plusnet support and BT don't want to know since I'm not a customer with them.
Fixes: 585
@Starlink666 I'll have another prod on the escalated thread but I'm pretty sure you're right , it's a BT problem.
I'm in a holiday cottage on a BT broadband connection and it doesn't resolve with their default DNS either.
Fixes: 251
This is well escalated and is being investigated, however "They have changed the nameservers again as well which is hampering investigations.".
The issue appears to be out with Plusnet and has been reported to impact BT Retail and EE users.  Leaving the name servers alone to allow full propagation of the the domain name might be more helpful to those investigating the issue.  Be assured that whatever the issue is, it is not a simple one.
Starlink666
Thanks. Enjoy your holiday! Smiley
Starlink666
Thank you. It was last Wednesday that I changed the nameservers but these were still managed by the same host. If they hadn't fully propagated by this morning (5 days later) on the BT servers than I wasn't expecting them to. All of the other DNS servers had fully propagated within 24 hours. So I thought I'd try swapping them over to Cloudflare. I won't be changing them again this week. Glad to know that it's still being investigated. Thanks again!
Fixes: 585
@Starlink666 try it now.
Its now working for me on a BT connection
RealAleMadrid
Fixes: 68
@Starlink666  Now working on Plusnet connection using Plusnet's DNS servers.😁  I wonder if you will ever find out what the problem was?
Starlink666
@MisterW Yes it does appear to be working again Smiley Hopefully it's still working again in the morning. Is it possible to find out what the issue was exactly? And if it's likely to recur?
Starlink666
@RealAleMadrid Yes, it would be nice to know exactly what the issue was and if it's likely to recur. Still, I'm just grateful that it appears to be sorted now.
