Plusnet 2704N router forgets device names
- Plusnet 2704N router forgets device names
26-09-2017 11:15 AM
I know this problem has been posted before, but I can't find any satisfactory solution. Devices regularly appear as 'Unknown' on the router information page, and referring to them on the network by their hostnames does not work, although the affected IP addresses do work.
Re: Plusnet 2704N router forgets device names
26-09-2017 3:31 PM
26-09-2017 4:09 PM
It's currently a Raspberry Pi and an iPhone, both over WiFi. Wired connections don't seem to suffer the same problem. The behaviour is fairly unpredictable, too. Sometimes you can still connect to a device using its hostname even when it is listed as 'unknown' on the device list. Other times that fails.
02-10-2017 6:14 PM
I have just received a 2704N and am having the same problems but with devices both on the wired and wireless network. It is making use of my home network a real problem. I have several raspberry pi's plus quite a few other devices and keeping track of them all by IP is really difficult.
02-10-2017 6:20 PM
Moderator's note:
Duplicate post removed.
Forum Moderator and Customer
