Plusnet 2 WiFi keeps dropping out
steve55cox
Fed up with this router, keeps losing the Wi-Fi signal, help anyone
24 REPLIES 24
Fixes: 382
Re: Plusnet 2 WiFi keeps dropping out
@steve55cox A bit more detail would help.  Do you mean you lose internet connectivity?
steve55cox
Ian using my I pad, wi Fi signal constantly disappears and returns.
I have restarted the router which is only about 5 weeks old and reset the I pad and reset the network connection
Fixes: 382
Do you have a desktop/laptop? - this sounds to me from the limited information to be a external network issue, and iPads are not the best kit to get the required data from.
steve55cox
Yes I have a laptop. What do you mean by an external network issue ?
Fixes: 382
OK. So does the  same issue occur on the laptop? By external issue, I mean a possible fault in the BT/OR network.
steve55cox
I’ll try the laptop later.
The blue light on the router remains constant so I assume it’s not losing the broadband signal ?
Fixes: 382
OK. I'll not comment further until you have tried the laptop, except to ask: do you move around much with the iPad?
steve55cox
When I used it yesterday I was sitting in the same place and it was not being moved
Fixes: 382
Thanks. A comparison with the laptops behaviour would be useful.Does the iPad default to 4G/5G when you 'lose' the Wi-Fi signal?
steve55cox
John, my iPad does have a sim so just cuts out as soon as the wi fi signal disappears. I rarely use the lap top so will have to fire it up and wait for it to update before checking. Steve
steve55cox
Does not have a sim
Fixes: 382
Steve - do you mean the 'iPad doesn't have a data SIM'?
steve55cox
As far as I know it doesn’t have a sim of any kind. I haven’t installed one and I can’t see anywhere to fit one.
Fixes: 382
FYI, all iPads, AFAIK, have a SIM slot on the side, but if you have never put one in, you probably haven't noticed it - they are identified by a 'pinhole' into which you push a small pointed object.
