PlusNet our slowest ISP so far - can get down to 8 kbps
- PlusNet our slowest ISP so far - can get down to 8...
06-07-2010 7:37 AM
We’ve been members of PlusNet now for just over a month and what a disappointment. Signing up was fine but once connected we took a massive hit on the broadband speed and frequently record speeds on www.speedtester.bt.com as low as 20 kiloBITS per second. As you can imagine this makes PlusNet unusable and not fit for purpose.
Today we received a phone message (after about 5 days) to say that we are connected at 672 kbps with a profile of 500 kbps and this was the best that PlusNet (&BT) can do, given the line length. However, the real problem is not the sync rate but the actual operational speed. It now takes minutes to load web pages and other speed testers vary from about 8 kbps to 200 kbps. After joining PlusNet I’ve notice that BT Wholesale has also downgraded the announced line speed. At one point the advertised rate was 1.5 Mbps now we see 0.5 Mbps.
Our previous (LLU) ISP had many faults but they did get 800+ kbps down the wire and sync speed slightly higher. Five years earlier even Tesco could manage 500 down the same copper wire.
All of this leads me to conclude that BT has inadequate equipment and that PlusNet have appalling network loadings. Their fault testing cycle is too long and a whole month goes by repeating the standard little tests, resetting the router, waiting 3 days – all tactics to divert blame to the end user. Always delaying and repeating and never making progress.
Given that the government aims to have broadband at 2 Mbps in every home by 2012 PlusNet and BT have a long way to go.
Message 1 of 3
(782 Views)
2 REPLIES 2
Re: PlusNet our slowest ISP so far - can get down to 8 kbps
06-07-2010 10:15 AM
I can see both profiles (our side and BTs) are set to 500, but a check for BT speed test results is showing nothing found. Are you still getting the slow throughput errors? If so please run another BT speed test (http://www.speedtester.bt.com) and we'll escalate it for more investigation for you.
Message 2 of 3
(364 Views)
07-07-2010 7:29 AM
Speed is up by a factor of 10(!!!!!!) on the last test. Speedtest.bt.com today reports 59kbps at 7am. About a week ago it was reporting <10. From memory the best this test has reported is about 150 kbps.
Typically the line seems to go in burst mode. I can see that the line operates at 400kbps for upto a second and them just stops for several seconds. SOmetimes the wait is 15 seconds. This means that complex web pages can take minutes to load. Google generally is the fastest because it is simple.
With a profile of 500 I would expect to get speeds well over 400kbps.
I notice the sync has dropped from 832 to 768, to 736 and now to 672 with no change in the SN. What will it be after another month?
Message 3 of 3
(364 Views)
