PlusNet legacy deal and adsl2+
FIXED- Subscribe to RSS Feed
- PlusNet legacy deal and adsl2+
Re: PlusNet legacy deal and adsl2+
11-11-2017 4:06 PM
You're right the 24th is a couple of weeks so time enough. At the junction of Camden and St John's is a Greene King pub, The Rifleman. Perhaps I should sit there and wait for the work to start!
But seriously, I don't absolutely need access to fibre broadband, all I need is a speed of at least 4Mbps so that I can download such things as updates to my TomTom satnav and the occasional bbc offering within a reasonable time (ie not all night).
11-11-2017 4:13 PM
Townman thanks for your detailed post.
I shall now leave the internet on 24 hrs a day. When can I expect the speed to pickup, after a week, a month, or is this a very long process? I should add, that I turn off my PC when not using it, therefore I will not have a complete RouterStats graph history.
11-11-2017 5:26 PM
If PlusNET have done a full line reset it will train for 10 day’s to try to establish the optimal synch speed. During this time I would anticipate seeing a few line drops. Having RS running to monitor this would be useful.
If there is intermittent interference it is essential if you seek to fully optimise the line.
12-11-2017 3:30 PM
OK I shall leave router stats on for a few days. The only interruptions so far have been when I turn wifi on or off. I don't like leaving it on in case some eavesdropper is nearby. There are flats close by with transient population especially at weekends.
Will PlusNet do a full reset automatically or do I have to make a specific request by email/phone?
13-11-2017 3:15 PM
The banding should be removed automatically, but we can put it through manually too.
With that said, your connection is still dropping heavily:
Testing your line at 3:10 when there was no active connection, showed your router in sync to the exchange still which indicates that your router was switched on but it seems that the drops we're seeing are due to a problem somewhere.
I'd recommend plugging your router into the test socket if you have one, and trying a different router if you can.
13-11-2017 6:10 PM
@Gandalf - would you know if the PlusNET routers maintain PPP in the absence of traffic (demand) ... or if the PC is turned off, do they drop PPP whilst maintaining synch?
13-11-2017 7:32 PM
13-11-2017 7:46 PM
@flinflon wrote:
My router is an old NetGear N150 wireless adsl2+ modem router (DGN1000-100UKS)
Or since it's not a Plusnet issued device, it could merely be configured with some sort of idle timeout for the PPP connection, so that it disconnects the PPP connection if no data has been sent over it for a certain time.
13-11-2017 7:50 PM
Thanks for reviewing the details - I am accessing on the phone - back reading is not so comfortable on the smaller format. Should have done so properly!!
13-11-2017 7:51 PM
13-11-2017 8:18 PM - edited 13-11-2017 8:21 PM
Something to check: In your router configuration where the Plusnet user name and password are set there may be an option for "Connection mode" - this should be set to "Always On".
14-11-2017 8:44 AM
As of last night (13Nov) I'm using test socket
14-11-2017 8:50 AM
It looks like your connection is still dropping a lot.
It may be worth checking this:
14-11-2017 8:52 AM
On the basic settings page of the DGN1000 setup I have changed "idle timeout" from default 5 mins to 0 min. I cannot find a "connection mode" box for "always on".
14-11-2017 8:57 AM
