PlusNet direct debit - new fees
fonebone
How am I getting an email today saying this months PlusNet debit will be the usual £11.49 for the 3Gb I have when I had an email on 6th August saying it would now be 2Gb + 1Gb = £9.99 + £1 = £10.99
I'm sure there's a reason for it
scrabble
Re: PlusNet direct debit - new fees
I seem to have the same problem.
I am supposed now to be on £9.99 (with 2GB included) plus an extra 2 GB at £1 each = £11.99 but am still being charged at the old price of £12.24.
Does anyone know why this is happening?
Grahamb
I to had the same problem.  I raised a ticket and was told it was indeed an error and I would be receiving a credit on my next payment.
fonebone
hmmm.. so, do we all have to raise a ticket or are we all being looked after..?
Fixes: 163
I've updated all your accounts, it seems that the usage was trying to charge the wrong amount. For example if you had 4GB of included usage it was charging for an extra 3GB instead of 2GB.
I've taken a note of your username and will get this investigated as a problem if I see any more examples.
 Chris Parr
 Plusnet Staff
fonebone
Many thanks Chris
running
I have got the same problem. £9.99 + £2 for 4GB = £11.99 less referrals £2.50 = £9.49 but I have been charged £9.74. Only 25p over but it all adds up. Should I raise a ticket?
Fixes: 163
I've fixed it manually for you and raised an internal problem to find anyone else affected by this.
 Chris Parr
 Plusnet Staff
running
Thanks Chris.
Heloman
I have the same problem.
I'm on Option 1 with 3GB included. Should be £9.99 + £1 = £10.99. I am being charged £12.49.
This is from "My Account" on the portal.
"21/08/2008  BP00569140  PlusNet Broadband Your Way Option 1 with included 3GB bandwidth  £12.49(monthly) "
James
Hiya,
I've just fixed this for you.
I've also put a discount on your account to account for the extra amount that you have been charged.
Heloman
Cheers James, but aren't I still being overcharged?
My Account now says;
"28/08/2008  BP00569140  PlusNet Broadband Your Way Option 1 with included 3GB bandwidth  £11.99(monthly)"
Surely Option 1, at £9.99, comes with 2GB . The extra 1GB costs £1 pre-paid. That makes.............................£10.99(monthly.
Or am I missing summat?
