PlusNet Pro Package v Broadband Your Way Pro
- PlusNet Pro Package v Broadband Your Way Pro
04-04-2009 6:31 PM
Ok i was looking at this package (the new PN Pro) and trying to compare it to my BBYW Pro , the only difference in wording that concerns me is "expected maximum downstream speeds" this says "Line speed- the fastest speed your line will support*" now my account says the below even thou i sync @ 4352 ip profile 3000 , if i switch to PN Pro will i only get download speeds of 1.5mb ? becuase BBYW Pro say "No Restrictions" this is my only concern .
Mark
Quote Telephone Number:
01908******
Post Code:
MK3 6JN
Phone Exchange:
MILTON KEYNES
Estimated Line Speed:
up to 1.5Mb
Mark
Message 1 of 5
(989 Views)
4 REPLIES 4
Re: PlusNet Pro Package v Broadband Your Way Pro
04-04-2009 6:39 PM
Estimated line speed is irrelevant - the fastest speed your line will support is exactly that and you won't see any slower speeds than you are presently getting
Message 2 of 5
(544 Views)
04-04-2009 7:06 PM
Cheers OldJim .
Message 3 of 5
(544 Views)
04-04-2009 8:06 PM
Trying yo change it to unlimited 18 month with hardware and free house move and it does not give the option to select hardware
Message 4 of 5
(544 Views)
04-04-2009 8:14 PM
You have to Ask JemeseH nicely just after you change, and it wont hurt to speak to the CS rep, but dont believe then some dont know.
Message 5 of 5
(544 Views)
