PlusNet Portal Failure - ongoing problem.
- PlusNet Portal Failure - ongoing problem.
21-12-2007 2:33 PM
Tried to log in to the PlusNet portal - http://portal.plus.net/index_nlp.html?home=membercentretop
But got "invalid username/password"
I phoned support, who tried my login/password from the support centre - where it also failed.
I have full internet access (except the portal), I can even access my webmail with this password.
Since my router also uses this password successfully, I assume it's just the Plusnet portal.
The CSR suggested I ring back in a couple of hours (about 2 hours ago) - but since I can't raise/view tickets I thought I would try bypassing this mechanism.
This isn't urgent - but I can't use any portal features.
Re: PlusNet Portal failure?
21-12-2007 2:49 PM
I've had problems before where you can't log in, which have been fixed quite quickly. Is this still a problem for you now?
21-12-2007 2:55 PM
21-12-2007 3:14 PM
Ex-Broadband Service Manager
21-12-2007 3:29 PM
21-12-2007 3:39 PM
http://www.plus.net/support/service/problems/problem.php?intProblemId=47394
the fix of which was what broke Metronet logins this morning. This problem has been upgraded back to a P1 and a developer is looking at it.
21-12-2007 3:43 PM
21-12-2007 3:48 PM
Quote from: Kelly This looks like it is related to:
When I look at the above link it says that the problem has been "downgraded".
Quote Problem: [47394] [Hopper] [live Testing] Portal Login Broken Status: Downgraded
21-12-2007 6:19 PM
Fix for that problem is in testing now and should be live soon.
21-12-2007 7:02 PM
21-12-2007 11:15 PM
Can't log onto portal
29-12-2007 12:51 AM
Re: Can't log onto portal
29-12-2007 2:00 AM
Make shoure that you tipe your Password & Username in the same Case, so for example if your Username was:
ben & you put Ben then it will fail.
Have you changed your (Password)? if yes try your old one.
29-12-2007 11:40 PM
Had it for the last 3 days and still the same today. I think the portal is having a wobler as last month my usage was 0 for one day even when I was on all day. My IP profile can change from 2 pm to 9 pm. One day it was 4meg at 2 pm th enext day it showed 2 meg and at 10pm it was back to 4meg
Trouble logging in
30-12-2007 9:21 AM
Anyone else having trouble ?
P.s sod's law isn't it ?
I post on here I'm having trouble, I go back and have another go and it lets me in.
