PlusNet Outgoing Mail Problems
- Re: PlusNet Outgoing Mail Problems
05-10-2007 7:57 PM
We have just moved from CharityDays to PlusNet - I have changed my SMTP server setting to relay.plus.net - but still no emails can be sent.
Incoming emails are OK.
My Outbound email addy is set up as hello@blackwhite.uk.com which is translated to a Tiscali account (and I pick them up Ok via Tiscali POP Server). Anyone any ideas?
05-10-2007 8:04 PM
1) You are on a PlusNet IP
2) You have not set outlook to require SMTP authentication
Try the following from a DOS prompt:
telnet relay.plus.net 25
And check you get a welcome message like:
220 relay.plus.net ESMTP Exim Fri, 05 Oct 2007 20:01:39 +0100
If you cannot connect then that is the fiorst problem to solve:
First, try rebooting PC & router/modem
Second turn off any firewall or A/V software temporarily to see if you can connect.
05-10-2007 8:51 PM
I'm trying to send an email to 200'ish people - is there a limit on the number of emails it can send?
I tested by sending myself one email and it worked OK.
I then sent an email to 10 of my 200 contacts - that worked OK!
But now it will not send anymore again!
05-10-2007 8:55 PM
Try sending a single e-mail to yourself, then log into web mail and see if it isn't in the mail filter.
I found from experience if you send an e-mail with "test" in the header it ended up in the spam bucket! The send mail was actualy working!
05-10-2007 9:21 PM
The number of emails you are sending would be subject to tarpitting however it wouldn't result in the error you're getting.
It's definitely a local issue as I can send an email from your domain when telnetted to the server and it arrives successfully:
C:\Users\Bobby>telnet relay.plus.net 25
220 relay.plus.net ESMTP Exim Fri, 05 Oct 2007 21:12:53 +0100
helo moto
250 ptb-relay03.plus.net Hello moto [80.229.150.170]
mail from:hello@blackwhite.uk.com
250 OK
rcpt to:me@privacy.com
250 Accepted
data
354 Enter message, ending with "." on a line by itself
subject:test
this is a test email
250 OK id=1IdtYA-0003QN-Om
quit
221 ptb-relay03.plus.net closing connection
The error is normally seen if one of the following conditions exists:
- The 'from' address in your mail account properties is incorrect
- You are not connected via PlusNet
- Your virus or Internet security software is playing up
- You are not actually using relay.plus.net to send
06-10-2007 11:50 AM
* The 'from' address in your mail account properties is incorrect
I am using "hello@blackwhite.uk.com" and send simple emails with no problem!
* You are not connected via PlusNet
Checked and double checked and I am connected to PlusNet
* Your virus or Internet security software is playing up
Stopped it working and I still have problems
* You are not actually using relay.plus.net to send
Outgoing SMTP server is "relay.plus.net"
I will download another mail client to see if it works better!
Any other ideas are welcomed.
06-10-2007 6:43 PM
07-10-2007 9:39 AM
I am looking at a few new mail clients (although I really do not think it will work).
Still not sure why we have had this problem since we moved from CharityDays to PlusNet!
07-10-2007 9:57 AM
If it doesn't work still using Thunderbird, then it's probably not a configuration issue with the client(s).
