PlusNet Broadband Premier Option 1
lettuce
crikey, i've been on this tariff : PlusNet Broadband Premier Option 1
for what seems like an eternity, i notice the pro tariff is £19.99 a month, this may be good i i work from home a bit.
anyone know the advantages/disadvantages of staying with my now defunct olde worlde tariff?
Cheesy
1 REPLY
James
Re: PlusNet Broadband Premier Option 1
Hiya,
The only real advantage of staying on Premier is if you take advantage of the longer off peak hours (midnight till 4pm versus midnight to 8am on the newer products).
If you don't move large amounts of data between 8am to 4pm, then I'd recommend moving to Option 2 or Pro.
