PlusNET Hub one
etdsaunders
Fixes: 7
PlusNET Hub one
Hello,
I've seen the hub one is pretty much a BT home Hub (which supports ADSL)
Does the hub one support both ADSL/VDSL?Huh
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs Up
Fixes: 31
Re: PlusNET Hub one
The Hub One is based on the BT Home Hub 5A, both of which support ADSL and VDSL, BT Home Hub's 1-4 are only ADSL.
etdsaunders
Fixes: 7
Re: PlusNET Hub one
Thanks for the reply.
Just upgraded to fibre (going live on the 29th) however they didn't state about not plugging the router in till the date given? I'm assuming i can plug it in on ADSL and then it'll switch to vDSL on the 29th?
That's what i'm hoping anyhow  Wink
herojan
Re: PlusNET Hub one
I was in the same position
I set up my hub 1 a few days before and it happily connected to my adsl then on the day of the switchover it simply reconnected as VSDL
etdsaunders
Fixes: 7
Re: PlusNET Hub one
Thanks for confirming, live chat also confirmed the same. Looking forward to getting rid of this super fast technicolor 5852n  Roll eyes
mav:quote
