Plus.net with DLink 2640R Router
- Plus.net with DLink 2640R Router
07-02-2012 8:59 PM
Hi
I've just obtained a DLink 2640R router which I have connected successfully to my plus.net broadband. In the set up disk, it had the option to auto-config for Plus.net which I did - see the attached screen prints. Everything connects OK but it has been dropping. I only set it up yesterday so
1. does it take some time to 'bed itself in'?
2. is it compatible with Plus.net?
3.
Also, I'm not clear whether I'm on ADSL2+ and/or whether this is of importance for the new router.
Kevin
3.
Kevin
Message 1 of 3
(790 Views)
2 REPLIES 2
Re: Plus.net with DLink 2640R Router
07-02-2012 9:36 PM
I suggest removing that attachment as it gives too much information about your connection
You are on ADSL2+ or ADSL2 judging by the upstream sync rate
It may well take time to bed itself in - the actual information we need is the attenuation and noise margins as well as speed to judge how close to the bone the connection is.
Message 2 of 3
(347 Views)
07-02-2012 9:45 PM
Thanks, Oldjim. Will see how things go over the next day or so. Attachment removed
Regards
Kevin
Regards
Kevin
Message 3 of 3
(347 Views)
