Plus net router
- Plus net router
Plus net router
26-04-2013 4:22 AM
After mucking around for 3 weeks with my netgear I cannot get my wireless to work on my phone do you suggest that I purchase plus net router to hopefully eradicate this issue. I don't really want to change routers but if Imust do you aadvise it if so what is the cost.
Message 1 of 2
(582 Views)
1 REPLY 1
Re: Plus net router
26-04-2013 7:49 AM
I'm assuming you're phone works on other wireless networks? You might also want to try:
If you want a replacement router from us then we normally just charge postage and packaging. You only pay for the router if you leave during the following 12 months.
- Changing the wireless channel the router's broadcasting on
- If hiding your SSID, try unhiding it
- Try changing your wireless key
- If there's an option to switch between wireless types e.g. b/g, n etc. then try changing this setting to see if it works
Message 2 of 2
(243 Views)
