Plus net line speed
- Plus net line speed
Plus net line speed
06-08-2015 6:26 AM
for some reason Plus Net line speed has been stuck on 1.9 instead of the correct 2.5
Can someone please sort it out
Re: Plus net line speed
06-08-2015 9:34 AM
If this statement is correct, can you please revisit the justification for removing the portal link to the 'current speed' - "It is no longer needed because the problem of the PN profile not updating has gone away, thereby dispensing with the need for the link to this information".
06-08-2015 9:44 AM
I think you misunderstood what they meant by "gone away". They mean they couldn't care less if updates don't happen and they don't want the issue of dealing with instances where it doesn't update so it's better if the user is prevented from finding out.
06-08-2015 11:06 AM
and is still showing current line speed 1.9mb on a connection speed of 2880 as stated previously this should be
2.5 in line with the BT profile of 2.54.
06-08-2015 2:43 PM
See http://community.plus.net/forum/index.php/topic,141226.0.html
06-08-2015 5:25 PM
