Plus net Line speed
barny
Plus net Line speed
Good morning,
My bt line profile has been 2.57 and my connection speed 2917 since wed 3rd 5.30pm my
plusnet line speed is 1.9  please can you correct thank you
catelliott
Re: Plus net Line speed
I can see that the router you are using is about five years old, have you tried a different router? Smiley
Fixes: 20
Are you suggesting a cause of the Plusnet Current Line speed failing to update automatically is people using old routers?
Also there was a Billion 7800 dxl mentioned not that long ago.
catelliott
Hi ejs,
A faulty router could cause barny's broadband speeds to slow a little, indeed. I'm just trying to rule that out as a potential cause.
Must have missed that, unfortunately not had quite enough time to go that far back in the forums Smiley
Fixes: 21
Well, I'd guess just at the moment he'd like his Current Line Speed correcting to match the Current BT IP Profile Wink
barny
Thanks for the assistance my router is 7800dxl and less than one year old, the profiles are now matched. all is well !!
