Plus blocking VNC?
- Plus blocking VNC?
Plus blocking VNC?
21-07-2008 2:48 AM
Re: Plus blocking VNC?
21-07-2008 6:31 AM
I use VNC from work to my Premier-provisioned line at home so I'll give that a whirl when I get into the office (it was fine on Friday though).
Edit: Just got to the office and fired up VNC and it seems to be working fine. What happens if you run a probe on port 5900 from your Plusnet line here?
21-07-2008 8:04 AM
21-07-2008 8:37 AM
Phil
21-07-2008 10:31 AM
22-07-2008 2:09 PM
The OP shouldn't have any issues as a result of throttling. Not with the account type they are on.
22-07-2008 6:10 PM
If bandwidth is not an issue then it might have something to do with a software update on the PCs which might have affected the firewall settings - still guessing here as we don't even know what the respective OS' are.
01-08-2008 2:06 PM
I have disabled the plus.net firewall already. Ill check my settings again. Thanks
