Plus.Net Speed Problem
- Plus.Net Speed Problem
04-03-2012 5:38 PM
The troubleshoot site is just a massive delaying tactic, check this, check that, do a speed test 3 times (with an hour in between).
The question is, without going to Virgin (and heard their shocking at service) would I be any better with any other provider considering it would be working on BT line to the same exchange?
--- Just about to post this and am disconnected.
Re: ToonBall's Speed Problem
05-03-2012 3:31 PM
I can see you've raised a fault and it's with our team, thanks for that. We'll get you an update on there as soon as we can.
With regard to the faults troubleshooter, we understand that it can be frustrating but it's important for a couple of major reasons. The first and foremost is that it gives our fault agents the information necessary to investigate the fault, particularly the BT speed test results in the case of a speed issue like yours (though it's often the case that slow speed issues are caused by drops in connection, which leads to the DLM system - that's dynamic line management, which runs on the exchange equipment and automatically ensures that the line runs at its fastest possible stable speed - lowering the connection speed in order to stabilise the line). The second is to make sure that the fault isn't being caused by either the equipment or internal wiring at the customer's premises, as our suppliers will guarantee the connection up to and including the master socket but not beyond there. Unfortunately if an engineer attends and finds the fault is to do with either the equipment or internal wiring a charge of £60 will be issued.
Hope that helps explain, and I'm sorry that things aren't working as they should be at the moment. As I said we'll update you as soon as we can.
07-03-2012 7:15 AM
Not everyone has a second router / modem, so I except some actually buy another router when 9 / 10 it's not required.
As it happens I do, because I work in IT, and therefore know that bandwidth / connection issues general happen within the local exchange.
My support ticket was answered and now am up to an average of 12Mbps, which certainly an improve, and something that was improved within the local exchange.
Better but at the lower end of the BT Wholesale ADSL checker (10 - 19.5Mbps).
07-03-2012 1:38 PM
Re: Plus.Net Speed Problem
13-03-2012 7:31 AM
13-03-2012 3:34 PM
13-03-2012 7:53 PM
Tonights scores: speedtest.net - 9.7Mbps
BT speed tester - 8.66Mbps
So it's getting worse again.
14-03-2012 9:37 AM
20-03-2012 7:02 PM
But for how long? Well until I find an alternative ISP hopefully, several months of poor / unreliable service.
21-03-2012 10:59 AM
23-03-2012 7:44 PM
Speeds have been high unreliable since beginning of Feb, even outages. The more I log the problem the worse it gets.... Then am told for the hour that it reaches back to 12Mbps (it's with accept limits).
26-03-2012 11:19 AM
What router are you using? I can see you had the misfortune of getting a good speed result when we were testing. Were the poor speeds obtained when using wired or wireless? Were there any other programs running (possibly in the background) when you were experiencing the slower speeds?
Jojo
