Plodding Upload
- Plodding Upload
Plodding Upload
19-11-2014 10:54 AM
Re: Plodding Upload
19-11-2014 11:07 AM
Could you post your router stats please (http://community.plus.net/forum/index.php/topic,96155.0.html tells you how to find them).
Re: Plodding Upload
20-11-2014 2:57 AM
Internet
Connection Information
Link Status: IPv4 connected
IPv6 disconnected
Uptime: 39 days, 11:32:36
Data Transferred (Sent/Received) [MB/GB]: 995.57 / 22.43
Username: <snip>
Password: ********
Remember Password: Yes
TCP/IPv4 Settings
IPv4 State: Enabled
IPv4 Address: 46.208.43.57
Primary DNS: 212.159.6.9
Secondary DNS: 212.159.6.10
TCP/IPv6 Settings
IPv6 State: Disabled
DSL Connection
Link Information
Uptime: 47 days, 17:20:31
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 795 / 14,874
Data Transferred (Sent/Received) [GB/GB]: 1.17 / 25.37
If you need any other info. please let me know.
jim:green username removed mod:end
Re: Plodding Upload
20-11-2014 8:05 AM
[quote=Sample of full router stats]Uptime: 13 days, 19:49:20
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 832 / 8,128
Data Transferred (Sent/Received) [GB/GB]: 1.59 / 10.26
Output Power (Up/Down) [dBm]: 12.3 / 19.9
Line Attenuation (Up/Down) [dB]: 11.0 / 20.5
SN Margin (Up/Down) [dB]: 17.0 / 6.6
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 139 / -
FEC Errors (Up/Down): 1 / 0
CRC Errors (Up/Down): 27 / 228
HEC Errors (Up/Down): - / 546
Re: Plodding Upload
20-11-2014 10:59 PM
DSL Connection
Link Information
Uptime: 48 days, 13:24:48
Data Transferred (Sent/Received) [GB/GB]: 1.22 / 27.14
Output Power (Up/Down) [dBm]: 12.7 / 0.0
Line Attenuation (Up/Down) [dB]: 16.3 / 32.0
SN Margin (Up/Down) [dB]: 11.6 / 7.1
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 189,322 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 3,940 / 212,012
HEC Errors (Up/Down): 3,133 / 1,579,014
Re: Plodding Upload
20-11-2014 11:24 PM
@Anybody: Does anyone know what the normal target noise margin is for upstream?
Re: Plodding Upload
21-11-2014 10:16 AM
Rx-Noise=6.1 Tx-Noise=9.2 Rx-Sync=4419 Tx-Sync=888
So I assume 9dB interleaved is normal
Re: Plodding Upload
21-11-2014 10:32 AM
With 48 days up time stability obviously isn't an issue!
@Wingco39 Could you try doing a graceful resync in the middle of the day please (wait till tomorrow if needed). To do that click disconnect in the router interface, then power off the router and leave it for a minute or so. Then power it back up and if it doesn't connect automatically after a couple of minutes click connect.
When you've done that please post the full stats as in your last post again. If you could also repost them at least 6 hours later we can see how many errors are being logged.
Re: Plodding Upload
24-11-2014 5:42 PM
Re: Plodding Upload
25-11-2014 1:21 PM
Uptime: 0 days, 0:00:35
Bandwidth (Up/Down) [kbps/kbps]: 1,227 / 15,437
Data Transferred (Sent/Received) [kB/kB]: 21.92 / 42.33
Output Power (Up/Down) [dBm]: 12.8 / 0.0
jelv At 13:21 hrs today
Line Attenuation (Up/Down) [dB]: 15.9 / 31.5
SN Margin (Up/Down) [dB]: 6.0 / 6.1
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 1
Re: Plodding Upload
25-11-2014 1:30 PM
From
To
You should be able to get a bit more from your upload now assuming all stays like that.
Re: Plodding Upload
25-11-2014 9:00 PM
DSL Connection
Link Information
Uptime: 0 days, 7:40:13
Data Transferred (Sent/Received) [MB/MB]: 3.15 / 13.40
SN Margin (Up/Down) [dB]: 6.2 / 5.9
Error Seconds (Local/Remote): 1,533 / 0
CRC Errors (Up/Down): 84 / 1,895
HEC Errors (Up/Down): 173 / 13,438
Re: Plodding Upload
25-11-2014 9:39 PM
Re: Plodding Upload
26-11-2014 4:18 PM
Re: Plodding Upload
26-11-2014 5:05 PM
