Please update my current line speed!
- Re: Please update my current line speed!
04-04-2012 11:21 PM
For three days, my sync speed has been between 6.1 and 6.3 Mbps. But the PN current line speed is showing as 5 Mbps. Please would someone give a nudge to bring them into line? (Username granway).
Chris
Chris
Message 1 of 2
(701 Views)
1 REPLY 1
05-04-2012 12:11 PM
To do this I'd need to run a line check first for you to verify the line rate and the synch speed, however the test I've just performed shows that the line is out of synch.
Have you disconnected or powered off your router?
Message 2 of 2
(296 Views)
