Please tell me there's a fault and this isn't the speed I have to put up with
lufc405
My speed is normally 0.3 at best but now its got even worse, its taken 45 minutes just to load this tab so I can write in to ask is there a fault. Took computer yesterday to my daughters to see if the fault was with the computer, it worked perfectly, as I said speed was never brilliant but now its next to nothing Any ideas Plusnet
1 REPLY
Fixes: 170
Re: Please tell me there's a fault and this isn't the speed I have to put up with
Although testing isn't flagging up anything specific, your sync speeds do seem lower than I'd expect (Even given the low estimates for your line)
I'd recommend going through our troubleshooting guides in the first instance here: https://www.plus.net/help/broadband/connection-troubleshooting/
However if you continue to experience problems, please could you report this over at http://faults.plus.net
Thanks.
 Harry Beesley
