Please review for me
- Please review for me
11-03-2010 6:47 PM
I obtained the attenuation from my router and the calculator got the distance spot on which leads me to suspect I could get a 6000 profile. Would this improve things if I did?
Please note I am not suggesting I have a fault but I am trying to get the best out my package.
Re: Please review for me
11-03-2010 6:55 PM
12-03-2010 8:05 AM
12-03-2010 8:20 AM
Can you grab up/down synch speeds and noise marging.
12-03-2010 8:22 AM
Info on how to get them can be found here http://www.kitz.co.uk/adsl/frogstats.php
Edit: Adie got in before me
12-03-2010 11:00 AM
We need a thumbs-up smiley
12-03-2010 3:42 PM
Type: Fast
Line Coding: Trellis On
Status: No defect
Downstream Upstream
Rate (Kbps): 5472 448
SNR Margin (dB): 14.3 19.0
Attenuation (dB): 39.0 21.5
Output Power (dBm): 12.1 19.8
Super Frames: 31284749 31285415
Super Frame Errors: 3821 381
RS Words: 0 0
RS Correctable Errors: 0 0
RS Uncorrectable Errors: 0 N/A
HEC Errors: 2434 336
OCD Errors: 4 250
LCD Errors: 0 68
Total Cells: 2568770874 0
Data Cells: 16420552 0
Bit Errors: 0 0
Total ES: 3753 0
Total SES: 12 0
Total UAS: 46 0
12-03-2010 10:07 PM
Quote SNR Margin (dB): 14.3
That would be what is keeping your synch speed below the estimated speed you have seen.
Ideally it would be around 6.
Can you describe your internal wiring?
13-03-2010 3:40 PM
No idea what path it takes but guess it would be around 10m with the convolutions.
Have considered putting router into test socket and then getting a REALLY long Cat5 but need to wait until stair carpet is replaced in a month or so.
Only one phone and it goes into the same socket as router via a filter.
Nothing else on phone system at all.
I would put router into test socket and go wireless but it's too laggy for gaming.
13-03-2010 3:48 PM
13-03-2010 7:28 PM
13-03-2010 9:25 PM
14-03-2010 8:42 AM
Interestingly last night just after 12 the speed jumped to 4.5meg
