Please review for me
Lorenzo48
Can someone please look at theses screenies and see if there is any room for improvement with a profile alteration? Noting the exchange info say 4500 is a conservative estimate.
I obtained the attenuation from my router and the calculator got the distance spot on which leads me to suspect I could get a 6000 profile. Would this improve things if I did?
Please note I am not suggesting I have a fault but I am trying to get the best out my package.
12 REPLIES 12
Fixes: 1,483
Re: Please review for me
You missed out some of the most important information, the stats from your router. Smiley
Lorenzo48
39db is there, what else do you need please and I'll get them posted.  Smiley
Fixes: 1,483
Noise margin is probably the one that's missing.
Can you grab up/down synch speeds and noise marging.
Strat
Fixes: 565
Downstream SNRM, the speed your router is syncing at for starters.
Info on how to get them can be found here http://www.kitz.co.uk/adsl/frogstats.php
Edit: Adie got in before me Roll_eyes
Lorenzo48
Right-o thanks chaps. Will get back later when I am at home.
We need a thumbs-up smiley  Smiley
Lorenzo48
Mode: G.DMT
Type: Fast
Line Coding: Trellis On
Status: No defect
  Downstream Upstream
Rate (Kbps): 5472  448
SNR Margin (dB): 14.3  19.0
Attenuation (dB): 39.0  21.5
Output Power (dBm): 12.1  19.8
Super Frames: 31284749  31285415
Super Frame Errors: 3821  381
RS Words: 0  0
RS Correctable Errors: 0  0
RS Uncorrectable Errors: 0  N/A
HEC Errors: 2434  336
OCD Errors: 4  250
LCD Errors: 0  68
Total Cells: 2568770874  0
Data Cells: 16420552  0
Bit Errors: 0  0
Total ES: 3753  0
Total SES: 12  0
Total UAS: 46  0
Shocked
Fixes: 1,483
That would be what is keeping your synch speed below the estimated speed you have seen.
Ideally it would be around 6.
Can you describe your internal wiring?
Lorenzo48
Router plugged into upstairs wall socket which is obviously wired down the master socket.
No idea what path it takes but guess it would be around 10m with the convolutions.
Have considered putting router into test socket and then getting a REALLY long Cat5 but need to wait until stair carpet is replaced in a month or so.
Only one phone and it goes into the same socket as router via a filter.
Nothing else on phone system at all.
I would put router into test socket and go wireless but it's too laggy for gaming.
itsme
Have you removed the ring wire at the master socket? http://www.kitz.co.uk/adsl/socket.htm
Lorenzo48
Yep, about 18 months ago, got a good jump in speed initially but speed has slowed over time. Down about 1 meg.
Fixes: 1,483
You could always try putting it in the test socket for a short period to see if that gives you an improved download speed.
Lorenzo48
Will try it when I don't have time to game.
Interestingly last night just after 12 the speed jumped to 4.5meg  Shocked
