Please reset my line
- Please reset my line
Re: Please reset my line
24-06-2015 6:28 PM
Ah OK Chris, we'll see what happens and see what Graham's reply is., except he has as I was typing
24-06-2015 6:30 PM
Interleaving on: depth 96 DS 8 US
SNR 6
Far SNRm 14
Atten: 26 dB
DS actual PSDL 20.0 dB
US actual PSD: 11.9dB
24-06-2015 6:31 PM
24-06-2015 6:37 PM
24-06-2015 6:41 PM
The stats usually are after that sort of test unless something is seriously amiss.
24-06-2015 6:45 PM
Ok no worries, will see what Chris reports,
I still have a bog-standard Thomson TG585 v7 from years ago when I "migrated" to plusnet from Waitrose/MAAF.
Draytek in use as we use Draytel voice for business.
24-06-2015 6:49 PM
24-06-2015 6:50 PM
Does that Draytek have the ability to set the Target SNRM btw, just worth asking, you haven't got it set, but in any event that won't explain the US anomaly.
Edit. Well as I typed ......
Don't forget to do graceful disconnects when you go swapping.
24-06-2015 6:52 PM
I can also do a reset on the Draytek and go back to previous backup config - shall I do that before swapping to the Thomson as I've noooo idea whether it is setup for my logon or anything!!!!
Popping out for 20 (domestic commitment) - leave it with me guys and I will try a reset Draytek and if no joy I'll try the Thomson. I'll pick this up again in 1/2 hr. Appreciate all the help so far
24-06-2015 6:55 PM
Edit: No problem.
24-06-2015 7:43 PM
Have re-run the btw speed test with additional diag (with Thomson in use) so results sent to their server.
11.9 down
0.69 up
Will put my original Draytek back after an hr uptime for the Thomson, in readiness for tomorrow. The router change had no effect on the sync.
24-06-2015 8:15 PM
24-06-2015 8:38 PM
About to swap back to the Draytek.
Hopefully Chris will pick this up again tomorrow.
Thanks again.
UPDATE: Draytek reconnected at same sync as before on Draytek 16Mbps down .88 up SNR 6 Loop Att: 26
24-06-2015 9:05 PM
25-06-2015 5:27 PM
Will publish telnet stats later but have plusnet lost interest?
