Please help with speed and disconnect issues
- Please help with speed and disconnect issues
- « Previous
- 1
- 2
- Next »
Re: Please help with speed and disconnect issues
29-05-2010 5:16 PM
What sort of sampling would you suggest as default is currently 15secs for noise margin up/down and conection speed of router
Message 16 of 20
(514 Views)
29-05-2010 5:19 PM
I would suggest sampling every 60 secs with 1000 points per page - gives about 16 hours per page
The lines should be flat but the noise margin will drop a bit after dark.
The point is that something is hitting your sync speed and this may help identify it
if you have the option can you also graph the errors per 15 minutes as this can give a guide to problems
Message 17 of 20
(514 Views)
29-05-2010 5:45 PM
sampling set but no option to set the errors on the lite version as far as I can see, will look at the full version and get my thick head round it just in case this doesnt show what is required
Message 18 of 20
(514 Views)
30-05-2010 9:12 AM
router has been up for 18hrs no problems, if you let me know what information you want me to post oldjim I will do say later this afternoon/early evening when we will have had 24hrs uptime (hopefully).
Message 19 of 20
(514 Views)
30-05-2010 3:57 PM
No re-syncs in the last 24hrs, connection has been stable when used for gaming and surfing etc. Line sync speed is currently 11788kps and the last noise graph taken is below
Message 20 of 20
(514 Views)
- « Previous
- 1
- 2
- Next »
