Please help! Router authentication issue for new customer
- Re: Please help! Router authentication issue for n...
Re: Please help! Router authentication issue for new customer
16-01-2018 6:09 AM
16-01-2018 7:55 AM
16-01-2018 8:09 AM
16-01-2018 8:11 AM
16-01-2018 2:05 PM
I can see we've picked up the fault ticket already and raised a potential line fault to Openreach.
It's a bit odd, because when we tested your line previously and raised this fault to our suppliers, they found no issues so didn't progress the fault report to Openreach. But I can see it's been progressed now.
Fingers crossed it's fixed within the next couple of days.
16-01-2018 2:44 PM
16-01-2018 4:04 PM
From the message you've received, it sounds like the test details were connecting and not connecting at the same time.
There don't seem to be any connection attempts coming through to our suppliers systems so it's likely that Openreach fault we've found is the cause. Regardless of the username/password you're using we should still see some attempts.
16-01-2018 4:44 PM
It's on the wrong dslam port in the exchange,
16-01-2018 5:03 PM
@harrow We'll see. Would be interesting to find out the cause of the problem. (And even better to have it fixed)
16-01-2018 5:22 PM
17-01-2018 3:57 PM
Look the easy way to prove this is to put a router on the bar pair on the MDF that will prove that it is jumpered to the correct dslam port,
when you integrate the dslam you will see the router,
it's not rocket science.
17-01-2018 4:01 PM
Should say interrogate the dslam,
chose the wrong spelling !
18-01-2018 3:15 PM
18-01-2018 6:56 PM
Line is now testing good checked to see broadband was working and is connecting to my tester so should be working at home, if not try turning off & on and resetting
It’s still not letting me connect with my username and password... “we couldn’t connect you to the internet. Please check your username and password and press the connect button”
I just don’t know what else to do!
Julian Openreach
18-01-2018 7:15 PM
His jdsu or exfo tester could a broadband signal,
but it was not the right one.
